Problems with HID's Kit Flickering? Possible Solution
Discussion in '8G Lancer - Customization' started by kinkbmxrydr, Nov 15, 2007.
  1. thetaxguy
    Yep, I tried all of the above mentioned ideas... no bueno. Oh well...
  2. thetaxguy
    This relay harness was designed so that you do NOT have to splice the OEM harness. I would rather just leave my lights on all the time then to mess with cutting wires. But that's just me.
  3. chetman7
    ^^ if ur talking about the relay harness that is posted in the first post...I am almost positive it will not work without splicing some wires. Where do u plan on hooking the relay to?
  4. BLACK-GTS
    BLACK-GTS Member
    hey remember that just wrote about relay wires so went to hidlook.com and i send a msg about the relay wires i tolk them that i saw a coment that the relay didn't work and they just call me today 23 nov his is Joe he told that there is many way make the relay work and he's working on it for diseable the DRL also he asked me wich one is the forum that one we talk about this problem and i told him, and then he told me that he gonna post some solutions for us ... but if you guys can go to hidlook.com and sent a msg he gonna see the demand and he give us more preority to us i think he can help us...
  5. thetaxguy
    The OEM harness for the driver's side headlamp. Through the "magic" of capacitors these harnesses were designed NOT TO BE SPLICED INTO THE STOCK WIRING HARNESS. Comprende?
  6. chetman7
    well of course it wasn't meant to do that..if it was we wouldn't have to splice.....but it will work
    so ...u tap for ppower on parkinglights.....wen uturn ur parkinglights on..it sends power through the relay and trips the fuse and walah.....
    I'm not drawing all my power from the parkinglights..i'm just using to set off the relay and telling it to get power from the battery
    and it doens't have to be the drivers side headlamp.....mines on the passenger side.it doens't matter
    Comprende?
  7. thetaxguy
    You're obviously missing the point entirely. Please refrain from responding to posts that you do not understand. Got it Ace? :roll:
  8. chetman7
    ok thats fine..I'll sit back and let u uys figure this whole thing out...I disabled my DRL's already so I guess its not my problem anymore
    My initial intensions were to help ppl with this problem in which I got solved..not to start fights and bickering
  9. WildBill
    Woah...chill out yall...share info and compare, not beat each other up with it. If you disagree, state why, and then let the other person counter as necessary. Nobody gets anywhere by name calling...
