how did u get the silver collar off (After you pull it down)? did u break it off? i'm having trouble. what can i do to take it off. thanks
its is a real pain in the neck.. but you need to pull it down like theres no tomorow... if you arent using it any more and dont care about scratching it, get a BIG flathead screwdriver an ram it between the rubber and the silver sleeve and then twist the screw driver..... it is a bitch, you gotta use some elbow grease.... thats not even the worst part... wait till you get to the top part rofl
ok so im having a trouble and half getting that little silver piece off. I got it pulled down that was no trouble but getting it off is another story. it has to come off in order for you to depress the little tabs to slide it up right? ok so edit from my above I got the silver sleeve off but now i cant lift it up. Be prepared to ruin your knob if your going to do this. Followed instructions but when i push in the little tabs the damn thing still wont come up. I am assuming the tabs on the bottom are the ones your suppose to depress. A friend of mine tried for 1 hour and still couldnt get the damn things off. Help please really dont want to go to the dealer to try to get the silver piece repaired.
