If you got it wired correctly with bluetooth accessory you should be able to hear voice through the right door speaker. Also it shows messages on your radio display. Ask dealer about it they should help you.
Mine has problems connecting also, tells me phone is not available when it is. When it does connect then it will drop and I dont know about it. Ive also had it lock up the stereo a half a dozen times or so, the only way to fix the blank screen is to turn the car off then back on, it resets the unit.
