2004 Lancer Sportback TURBO Ralliart
Discussion in 'Members Progress Reports' started by illusiondweller62, Mar 9, 2014.
  1. illusiondweller62
    illusiondweller62 Well-Known Member
    April 22, 2013...
    "Hack says my turbo reflash is done...manifold and piping being shipped this week.
    This stencil is going to happen as well (photoshopped rendition shown):
  2. illusiondweller62
    April 27, 2013...
    "Honey? I'm home!" -Jack Nicholson in,The Shining-"
  3. illusiondweller62
  4. illusiondweller62
    April 29, 2013...
    " I know this isn't what you guys are waiting for, but it's raining here, and although "snails" do come out in the rain, the good stuff will have to wait.
    For now, this is what came to fruition:
    After centering the adhesive stencil, I masked off and left these letters exposed then applied four coats of a darker red to better match the car:"
    ...Then, I exposed these symbols and tried to apply a fade to the end by shooting steady to the left of the stencil, then sweeping quickly to the right. I applied four coats repeating this technique each time:
    Using a blow dryer to expedite my impatience in the moisture, I unmasked and remasked for the bottom letters and applied four coats of gloss black:
    Shooting photos from the front didn't do justice (lighting issues) so I played with different angles and came up with these which, appear to show the proper effects. I hope Michael and Brent approve:"
  5. illusiondweller62
    The Original:
    The Photoshop:
    The Real Deal:
    It was a team effort Bakuro...have to thank God for that!
  6. illusiondweller62
    First fitment of manifold and turbo, May 01, 2013...
  7. illusiondweller62
    May 07, 2013...
    Turbo mod (in shop)
    Intake Pipe MAF mod (in process by Hackish)
    Charge Piping couplers, and clamps
    Oil Pan bung for drain
    Tee Oil Pressure sensor for oil source
    Fab Downpipe and Cat Pipe
    Upload Turbo reflash
  8. illusiondweller62
    May 08, 2013...
    Still need a 90° elbow to connect these two. Hack says he haw one lying around:
    Ready to weld (L to R):
    LICP (compressor nozzle to IC)
    UICP (to throttle body)
    UICP (from IC, up overflow resevoir space)
  9. illusiondweller62
    May 16, 2013...
    Pipes all welded up:
  10. illusiondweller62
  11. illusiondweller62
    May 21, 2013...
    Couplers & Clamps came in today:
    The manifold spacer, along with the longer studs, should be in next week, as my car is going up on a lift hopefully next week as well. Here's what's left to modify / obtain:
    1. WG actuator bracket and lever
    2. Down pipe
    3. Cat pipe
    4. Intake pipe (Hackish is modifying)
    5. Oil pan bung
    6. Write reflash to ECU
  12. illusiondweller62
    May 22, 2013...
    Thick 0.75" (ID) dishwasher tubing from Home Depot works primo for the recirculating valve...
    ...more pics tomorrow.
  13. illusiondweller62
    May 24, 2013...
    4g69 flange/spacer by RRE...these are laser cut which causes minor warping, so I "ponked" it (beat it with a rubber mallet) and it flattened out nicely:
    ..with two gaskets:
    ...with the manifold:
  14. illusiondweller62
  15. illusiondweller62
    M10 X 1.25 X 50mm (15mm in the block, 35mm exposed = 50mm)) studs installed:
  16. illusiondweller62
    May 27, 2013...
    While I wait, I tee'd off of the oil pressure sensor bung for my turbo oil source (located on the back of the block, driver side, behind the oil pan):
  17. illusiondweller62
    Vacuum source for boost gauge and recirculation valve, May 29, 2013...
    Ahh, okay, I got ya, I know that hose/connection...thanks.
  18. illusiondweller62
    June 08, 2013...
    I finally had the wagon towed to Profab's shop, for their lift is available...let the magic begin!....
  19. illusiondweller62
    June 12, 2013...
    Garrett 2.5" Flex Pipe...
    After spending four hours shooting down ideas, after my initial "paper towel roll" mock-up, as to why I didn't have enough room for a downpipe, the shop foreman finally agreed to go ahead with a twist on my original idea brought up by a humble worker overhearing our debate. 2.50" piping is going to be mocked up first to see if we can squeeze that in.
    Garrett, I could use that piping right around now.... I'll make do though if you can't...{thumbup}
  20. illusiondweller62
    June 18, 2013...
