Wheel
Discussion in '8G Lancer - Suspension' started by JDM FLOW, Feb 15, 2008.
Which wheel
  1. O.Z. Superleggera III
    0 vote(s)
    0.0%
  2. Gram Lights 57Optimise
    0 vote(s)
    0.0%
  3. SSR Type C RS
    0 vote(s)
    0.0%
  4. Enkei Racing RS-M
    0 vote(s)
    0.0%
  1. JDM FLOW
    These are the one:
    O.Z. Ultraleggera
    Offset: 48mm
    Bolt Pattern: 5-114
    Rec. Tire Size:215/45-18
    **Lightweight: 18.4lbs.**
    Note: Vehicle Has TPMS
  2. eKtor
    none of them... get the ultraleggeras in 19" gunmetal
  3. JDM FLOW
    Was going to put those too but you beat me to it.
    Hector what's the name?
    O.Z. Superleggera III ?
  4. GTS-SB
    GTS-SB Well-Known Member
    you should post pics of all the rims so we can compare.
  5. JDM FLOW
    Will most likely get the one's Hector put up.
    :D for you flow [​IMG]
  7. JDM FLOW
    :roll:
  8. EBlancerGTS
    EBlancerGTS Well-Known Member
    Get the O.Z.'s
