I installed 2 12" Kicker Subwoofers not to long ago. But now i am starting to get a rattling sound from the big plastic cover that is located behind the rear seats/ below the rear window. this is from the bass of the subwoofers. the problem is that i dont know how to stop this rattling noise....anyone know of a way/have suggestions?
dynamat dynamat dynamat.. ORR what else sometimes works and is cheap.. that egg crate material ppl put on mattreses.. get that and pull the back dash off and put it under it.. it will make it fit snug.. dang that reminds me I havent matted my back deck and roof.. THANK YOU
dynomat wont work bc the platic part rattles bc its not tight enough but yes... how do you remove the plastic covering?
Try come Coremat or you can even run a small bead of silicone around the edge (where it can't be seen) and but it back on. But a couple of heavy book or dumbbells on it to push it down. This will dry and hold the panel down and minimize the rattling.
