RRM Camber Kit Info
Discussion in '8G Lancer - Suspension' started by delphium_, Mar 5, 2008.
  1. delphium_
    delphium_ Well-Known Member
    So i was wondering, what does a camber kit DO?
    What does it lower in order to make the tire wear even.
    And if i were to drop mine even though it wouldn't be an extreme drop and i wouldn't NEED a camber kit, would i benifit from throwing one on anyway?
    -thanks
  2. blacksheep818
  4. delphium_
    I've already read that thread, doesn't answer my question..
    and fyi i did search and didn't find an answer to my question.
    I tried googled but it showed me abunch of links to camber kits not what they do and how they sit and where their installed and stuff.
    I just wanted to know how a bolt fixes the camber.. where it goes and if it'll benifit me if i install one or if i'm just wasting money because i really dont need one.
  5. blacksheep818
    put it this way you dont need it because the springs that are out are not that extreme, the only thing you would need to do is a alignment its pretty much what was said on the other thread
    /\ To add, extreme drops would be more than a 2" drop...the lower springs that are available for the 08 have a drop of no more than 1.5" maybe 1.8". So you really dont need a camber kit for the 08 Lancer. Butt you will need an alignment after the springs have been installed.
    wasting money
  7. delphium_
    Thanks sheep and bras,
