For Sale Road Race Motorsports Next Stage Power Pro (Timing Controller)
Discussion in 'Private For Sale' started by egret85, Apr 7, 2013.
  1. egret85
    egret85 Well-Known Member
    I have the Road Race Motorsports Next Stage Power Pro (Timing Controller) for sale for $150.
    Purchase can be completed on ebay at: http://www.ebay.com/itm/281089930591?item=281089930591&viewitem=&vxp=mtr
    Had it installed on my car for a couple months before trading it in. From the RRM site:
    Introducing the all new Next Stage Power Pro. This box will revolutionize the way that you modify your car. Expect 8+ HP in minutes by simply plugging in line with your MAP sensor using factory style plugs. This unit is undetectable by the dealer once removed. It takes 2 minutes to install and comes complete with instructions. This unit unlocks the power potential that is untapped by modifying the MAP sensor signal to your ECU and advances ignition timing. It will work along with the RRM ECM system and all other RRM parts short of a turbo kit. The Next Stage Power Pro dynoed alone made 8+ wheel horse power. This unit is truly plug and play and built to military spec. This means it will handle under hood heat, moister and vibration to insure a long reliable life
    - Proven to add up to 8 wheel horsepower on Mitsubishi Lancer
    - Easy plug and play installation using OEM connectors
    - No cutting of wires required!
    - Compatible with Mitsubishi Lancer
    - Works with stock or modified vehicles
    - Made in the USA
    - Will work for both manual and CVT transmission vehicles
  2. 04sportback
    04sportback Member
    What year lacer?
  3. Jogenmaru
    08-12
    Sent from my SCH-I535 using Tapatalk 2
  4. 04sportback
    04sportback Member
    Oh crappy. Mines an 04.
