Removing Antenna..
Discussion in '8G Lancer - Customization' started by Keeeent, Sep 15, 2008.
  1. Keeeent
    Keeeent Well-Known Member
    Just got my sharkfin antenna from VG. How do I remove the antenna?
  2. Dotter
    Dotter Active Member
    unscrew it...
  3. lancer_ba
    lancer_ba New Member
    Dumb question, but how do you remove base plate.
  4. mikeike8
    mikeike8 Well-Known Member
    isnt there a bunch of wiring attched to it... i was thinking of getting the shark fin but i always thought the antenna was vital to my car and couldnt think of anywhere else to put the wiring??
  5. Dotter
    All you have to do is unscrew the long piece. The base stays attached to your car, the fin have a litte wire with screw provided that screws into the base of the antenna that is still attached to the car.
  6. RALLIART
    you dont remove the plate. You just take the original antena off, leaving the plate on, then you attach ( screw ) on the wire that came with your sharkfin, you screw that wire onto where your original antena was. then you apply the shark fin to the roof of the car, make sure you apply it first to check fitment, before you stick it on...
  7. lancer_ba
    Thanks guys.
  8. BCAPE
    BCAPE Well-Known Member
    does it get in the way of reception at all?
