possible reason of 08 lancer pulling to the left...
Discussion in '8G Lancer - Suspension' started by vik2rius, Jul 25, 2008.
  1. vik2rius
    vik2rius Well-Known Member
    hey guys...
    i know its a pain in the @&& for most of us that our car pulls to one side...
    heres a possible reason why...
    according to the new alignment that i got from my car the caster of the front tires are slightly uneven...compared to the previous 2 alignment that i have gotten the same result...the left caster is slightly uneven with the right caster, which is PROBABLY why the car wanders to the left...unfortunately in the 08 lancer it cannot be adjusted...
    FEEL FREE TO CORRECT ME IF I AM WRONG...PLEASE NO BASHING...IT WAS JUST AN EXPLANATION GIVEN TO ME...
    thank you
  2. Greedy_son
    Greedy_son Member
    Dont forget roads are sloped to shed water to prevent water build up and plus and extra 100 - 200 lbs in the driver seat it all adds up at high speeds.
  3. kennyjai
    kennyjai Well-Known Member
    if thats the case what do we do??
  4. BigSteve
    BigSteve Well-Known Member
    lose weight and find a road that not sloped? lol ^^^
  5. kennyjai
    hahaha lose weight is possible... straight road.... hmmmmm harder for me hahaha but now that i think about it.. when i am on straight road it doesnt pull to the left...
  6. nspunkrock
    nspunkrock Member
    and here i was thinking it was all the pot holes i hit around here knocking things out of line...
  7. Greedy_son
    Greedy_son Member
    Sit in the middle with your knob between your legs (gear knob :D ) and drive right down the centre of the road and make the other guys move out your way. (they will right? :eek: )
    Most cars will pull to the left under these conditions so dont feel that your alignment is always out.
  8. Eric1180
    Eric1180 Active Member
    if it where because of the roads the car would pull right not left
  9. lancered
    lancered Well-Known Member
    +1/\the water has to tread torwards the sides of the road(right)which will make you hold the wheel more left then right.if the water treaded left then roads all over the place would be flooded.
  10. GTS_Rob
    GTS_Rob Well-Known Member
    mine started pulling left today! 1st time i noticed it and it is BAD only 8k. No car ive ever had has pulled this badly!(and ive had some buckets!) ever.....anyone see the dealer and get this fixed??? if i take it to 3 times with no true fix i can lemon law the sucker huh??? im trading for ralliart soon so its not too important, but i dont want the Ralliart to do it too!
  11. vik2rius
    i think a lot have tried the dealer but no luck...what dealer do is change the tire pressure to compensate the pulling case
