JVC KW-AVX710 7-Inch In-Dash Double touch screen
Discussion in 'Private For Sale' started by Sinestra, May 10, 2011.
  1. Sinestra
    Sinestra Well-Known Member
    Hey guys this is feeler for my JVC 7" DD touchscreen all the info about the unit is below. Its two years old and in perfect working order. Along with the unit you will also get the Ipod integration cable, which allows you to control all your ipod features from the touchscreen which your run out the back of the unit into your glove box for a nice clean look. You also get the remote control. Shoot me some offers if youre interested.
    You can also buy a bunch of add ons for the unit like bluetooth,Sat radio,rear and a rear camera. However there is no navigation feature.
    * DVD Player
    * Video Format: NTSC
    * DivX(R) Compatible: DivX(R) ULTRA Certified Product
    * DVD-R/-RW, +R/+RW Compatible: Yes
    * Video DAC: 108MHz/12-bit DAC
    * DTS/Dolby Digital/MPEG Audio: Yes
    * GIGA MP3 MULTI: Yes
    * JPEG/MPEG 1/2 Compatible: Yes
    * Pause/Step/Slow: Pause/Slow (Slow function remote only)
    * Direct Chapter Access: Yes
    * Video CD Playback: Yes
    * Frequency Response: 16 - 22,000Hz (DVD fs=48/96kHz), 16 - 20,000Hz (CD)
    * Dynamic Range: 93dB (fs=48kHz)
    * Signal-to-Noise Ratio: 95dB (fs=48kHz)
    * Channel Separation: 85dB (at 1 kHz, fs=48kHz)
    * Wow amp; Flutter: Less than measurable limit
    * VCD Player
    * Video CD Playback Control: Yes
    * Direct Track Access: Yes (Remote Only)
    * CD Player
    * MP3/WMA Compatible with ID3 Tag/WMA Tag: Yes
    * WAV Compatible with WAV Tag: Yes
    * CD-R/RW Compatible: Yes
    * CD Text: Yes
    * Random/Repeat Play: Yes
    * CD Changer Control
    * MP3 Control: Yes (with CH-X1500)
    * CD Text: Yes (with CH-X1500)
    * Bluetooth
    * Bluetooth Control: Ready (KS-BTA200 required)
    * Hands Free Call: Yes
    * Audio Streaming: Yes
    * SMS (Short Message Service) Display: Yes
    * Phonebook Transfer: Auto
    * Voice Recognition Dialing (voice recognition compatible cell phone required): Yes
    * iPod/iPhone Control
    * iPod Control: Yes (J-BUS)
    * Play / Pause / Skip / Search: Yes
    * Text: Yes
    * Battery Charge: Yes (J-BUS)
    * Compatibility: iPod nano 1st, iPod mini, iPod 3rd, iPod with Click Wheel, iPod with Color Display, iPod with Video, iPod Video File Playback
    * Radio Tuner
    * Preset Stations: 18 FM + 6 AM
    * Station Name Registration: Yes
    * SSM (for FM): Yes
    * AFNS/PNC: Yes
    * Seek (Up/Down): Yes
    * Stereo/Mono Switch (for FM): Yes
    * Auto Antenna: Yes
    * European Switchable Tuner: Yes
    * FM Frequency Range: 87.5 - 107.9MHz
    * FM Usable Sensitivity: 11.3dBf (1.0uV/75 ohms)
    * FM 50dB Quieting Sensitivity: 16.3dBf (1.8uV/75 ohms)
    * FM Stereo Separation: 35dB
    * AM Frequency Range: 530 - 1,710kHz
    * AM Sensitivity: 20uV
    * AM Selectivity: 35dB
    * Amplifier
    * Maximum Power Output: 50W x 4
    * Continuous Power Output (RMS): 20W RMS x 4CH at 4 ohms no more than 0.8%
    * MOS-FET Amplifier: Yes
    * Audio DAC: 192kHz/24bit
    * Source-Specific Volume Control: Yes
    * Volume Attenuator: Yes
    * Balance/Fader Control: Yes
    * Equalizer
    * 7-Band iEQ: Yes
    * Max. Amp Gain Switcher: Yes
    * AV Input Terminals (Video + L/R): Yes
    * Line Output Terminals (pair): 1 Pair (Rear)
    * Composite Video Output: Yes
    * Optical Digital Output: Yes
    * Frequency Response: 40 - 20,000Hz
    * Load Impedance: 4 ohms (4 - 8 ohms allowable)
    * Pre-output Level/Impedance: 2.5Vrms/1k ohms
    * Pre-output level/impedance: 2.5V
    * Video Output Level/Impedance: 1.0Vp-p/75 ohms
    * Video Input Level/Impedance: 1.0Vp-p/75 ohms
    * Audio Input Level/Impedance: 1.5Vrms/20k ohms
    * Monitor
    * Screen Size: 7-inch Wide
    * Touch-Panel Operation: Yes
    * Screen Resolution: 480 x 3 x 234
    * LCD Type: TFT Active Matrix LCD
    * Color System: NTSC
    * Contrast Control: Yes
    * Switchable Dimmer: Yes
    * General
    * Face Type: Motorized Slide-Out Face
    * Steering Remote Control Ready: Yes
    * Wireless Remote Control Type: Easy-Grip
    * Beep Tone Support: Yes
    * COMPU PLAY: Yes
    * Tel. Muting: Yes
    * Power-Off Mode Eject: Yes
    * Dimensions (W x H x D)
    * Installation Size: 7-3/16 x 4-3/8 x 6-5/16 inches (182 x 111 x 160 mm)
    * Panel Size: 7-7/16 x 4-5/8 x 7/16 inches (188 x 117 x 10 mm)
    * Weight: 2.9 kg (6.4 lbs.)
  2. Jogenmaru
    Sounds like a good lil package. I might take this off you. Is there a usb feature? Im not familiar with the newer lancer things.
  3. 1slowlance
    We can't use double-dins...
  4. Jogenmaru
    We can with a double din conversion and some inginuity. (I think I spelled it right)
  5. 1slowlance
    I think it's ingenuity. That's too much work. Lol.
  6. lancer2quick
    buddy of mine is looking for a new 2din....but he dosen't have a lot of scratch to spend on one....just had a new baby.
  7. shieldwolf342
    ill be running double din as soon as my damn amplifier shows up but unfortunately the no GPS kills this for me
  8. Sinestra
    Unfortunately no it doesnt have a USB port i had no use for a usb since i was using my ipod for everything so it didnt factor in when i bought it.
    Im pretty reasonable just find out how much he is willing to spend the baby is way more important obviously
    GPS didnt really bother me i had a tomtom and i have GPS on my phone so i saved myself an extra 300-400 dollars when i bought it.
