/ Register
How wide of a rim can i use on my 08?
Discussion in '8G Lancer - Suspension' started by CanoboyGTS, Nov 22, 2007.
  1. CanoboyGTS
    CanoboyGTS Member
    How wide of a rim can I use on my 08 GTS?? I want a rim but it is only available in 18x8.5 anybody know if that would fit?
  2. Farmer11
    Farmer11 Active Member
    8.5 is the biggest you can go I THINK
    KRU fitted that size on his 08 and it scraped on the inside of his rears, i think. You can ask him about it.
  4. Payload
    Payload Well-Known Member
    all depends on the offset. With that sort of width having the right offset will make all the difference as to weather it fits or not. Probably easier to have it too far out because you can always roll the guards or add some camber .. theres not much you can do if its rubbing on the inside without alot of trouble.
  5. Guest
    19x8.5" with 45mm offset
    any wider with this offset and you will be h8n life.
  6. topher
    topher Well-Known Member
    KRU!! you didnt have any rubbing up front???
  7. Guest
    ^none
  8. kinkbmxrydr
    proper tire size as well
    ill be upgrading to 18x8.5
    with 225/40/18 tires
  9. topher
    KRU what tire size did you use on ur SEMA car?? 220/ 30/19
  10. Guest
  11. topher
    good to know thanks.. :lol:
