So I swapped my clutch and put everthing back where it belongs, I go to start it and I get nothing. I tested the starter and it is good, all I get is a clicking from the silonoid. Any ideas?
The clicking Is from the starter. There are multiple reasons why this could happen. Check all wires. Make sure they are clean. Check the ground for the tranny. No offense to you or anything, make sure the clutch is in right. Also, once the car does start you will smell a bit if burning from the clutch and flywheel. Also, check your battery. Sometimes it will drain. Try a rolling start to see if that gets it to starts up. Sent from my Galaxy SIII using TapaTalk
got it going, apearantly i had a dirty ground that was causeing my starter relay to short out. clutch is awesome, all grip and go. thanks for the good deal.
I will back Marcus with all his stuff...straight forward dude. Glad to hear you figured it out fairly quickly...
