HEAD - UNIT PROBLEM
Discussion in '7G Lancer and older- General Information' started by xxmisfits1, Jun 7, 2010.
  1. xxmisfits1
    xxmisfits1 Member
    so I installed a new head-unit i was having problems with the battery (wasn't screwed down properly) then this morning went out to get some stuff, was driving the head-unit wouldn't go on? and i was wondering anyone got some tips i could try to get it working?? i even had my friend who is good with subs/ electronics that kinda shit he didn't know what up either. anyone have help id appreciate it :D THANKSS
  2. shieldwolf342
    the fuse in the head unit may have blown or even any of the fuses along the line to the head unit i believe the one for the stereo is on the interior fuse box but first I would check the connection on the battery
  3. timschoeliertm
    fuses maybe, your faceplate might be loose as well
  4. 1slowlance
    Faceplate might be loose like shieldwolf said. Definitely go back and check all your wiring, and make sure everything is still intact. Battery connection and all that jazz.
  5. Jogenmaru
    Grounding issue. check fuses and make sure your unit is grounded properly.
  6. xxmisfits1
    xxmisfits1 Member
    okay so ill just check the fues and get back at you guys. im not sure if its the wiring it self because it DID work for awhile now it just messed up.
