Has anyone put 16's on their GTS??
Discussion in '8G Lancer - Suspension' started by Dotter, Sep 22, 2008.
  1. Dotter
    Dotter Active Member
    I want to do a smaller rim/better tire for winter. However, I contacted a dealer near me and they said that they don't believe 16's will fit due to the larger rotor size then the ES. Can anyone confirm this?
  2. kennyjai
    kennyjai Well-Known Member
    i think ur dealer should close down for being so misinformed.. lol 16 is the lowest u can go with gts
  3. brian95638
    brian95638 Well-Known Member
    thats what my dealer said about this as well lol.
    if 16's really do fit.. im gona get some steelies :D
  4. Dotter
    Have you've done it that your so sure? I don't want to waste my money to get them and find out they don't fit.
  5. kennyjai
    i havent done it but its all over the forums that 16 is lowest u can go due to the rotor size, i cant pinpoint where exactly but if u look around you'll stumble on it for sure!
  6. skullpr
    skullpr Well-Known Member
    well sorry to disappoint you guys and gals but 16's wont fit the GTS...at least not the 2009 one...i tried but the break caliper is in the way...17 is the smallest i can go, then again i dont know about the ES or the 08 GTS
  7. LuvMyLancer
    LuvMyLancer Well-Known Member
    I have 16s on my '08 GTS right now (steelies and winter tires)
  8. SoflaGTS
    SoflaGTS Well-Known Member
    doesnt the es come with 16's?? lol
  9. skullpr
    well i guess the break calipers in the 08 are diff than those one the 09
  10. TheGrub
    TheGrub Active Member
    I have a 09 GTS and my winters are on 16'' steeles and the caliper clears with a good inch..... no problems here..
  11. mitchGTS
    mitchGTS Well-Known Member
    16" do fit the 08 GTS. Got the winter steeles and tires on for winter.
  12. blkdout1
    blkdout1 Well-Known Member
    i have 16s on my gts for some reason my car wont stay in line and tires for my 18 kept wearing wrong and they were to expensive so I bouthgt 16s, 60 a tire :) instead of 170
  13. Answer
    Answer Member
    ^^ get an alignment!!!
