GTS SPecs
Discussion in '8G Lancer - Suspension' started by Redline1, Jan 27, 2008.
  1. Redline1
    I was wondering if anyone knew how much the GTS rims weigh
  2. blacksheep818
    All 2008 models
    Lug pattern is 5x114.3
    Lug nut thread/pitch - 12 x 1.5
    Center hub is 68mm.
    GTS
    Stock tire size is 215/45/18
    Stock tire is Dunlop SP Sport 5000 M
    Wheel is 18x7 (as found by solsonic)
    Offset is 46mm
    Weight of stock wheel/tire - 48 lbs. (as tested by gts_in_nj)
    Weight of stock wheel - 23 lbs. (as tested by dsrttigr)
    Weight of stock tire - 25 lbs. (by removing wheel weight from total weight)
    DE
    Stock tire size is 205/60/16
    Stock tire is Yokohama AVID S34B
    ES
    General info
    A 245/45/18 size tire will not fit, as confirmed by CrEsT (tested on 18x8 wheel). A 235-width tire will fit, however (see post #19 below).
    A 16" wheel will fit on the GTS model. It is the smallest wheel that will fit, though.
    i got these from evom so i think this should help
  3. Redline1
    wow really 48 pounds
  4. Redline1
    i was planning on upgrading my es with the gts rim
  5. Mitsu008
    yup heavy feet lol
  6. blacksheep818
    yup wheels and tires together
    like this:
  8. 5th
    wow that abvious that wont fit 245/45/18
    i wanna try 235/45/18 :]
    i think ill do that wensday and let everone know about the clearance
    wouldnt reccomend to drive on it though
  9. lancered
    lancered Well-Known Member
    dang thats heavy,i was planning on doing the same to my ES as well.
  10. Guest
    do it up 5th
  11. 5th
    yeah well rightnow the car is in the shop i just thought of that but working for goodyear ive learned some neat tire stuff..
    when my car is back im gonna check it for sure but for now 225/45/18 sunnys are in the front and i have no problem with those
  12. Guest
    glad to hear ur doing good with the job thing now and the car is getn handled.
    Good info on the tires.
  13. eTXlancer
    eTXlancer Well-Known Member
    does anybody know the rim/ tire weight on the ES
  14. Redline1
    yea just like that
