hmm i heard the only way to acomplish this is by rolling the fenders but is there any way to get past that? maybe a low profile tire? 18/8.5 235/35/18? or 240/35/18? idk im still pretty new to the whole rims and tires things
If you're dropped you will most likely need to roll your fenders, some go with negative camber, the rims I'm going with are 18x8.5 and I'm going to use a 235/40 nitto neo gen to try and tuck the tires in. Whether you rub or not is entirely up to your set up, if you're stock height you'll be fine with evo rims.
Yeah it's not so bad though, it's definitely an aggressive set up for this car so make sure you take pics!
