Do you notice any difference with strut bars?
Discussion in '8G Lancer - Suspension' started by mpirklbauer, Jan 26, 2009.
  1. mpirklbauer
    mpirklbauer Well-Known Member
    Hi,
    I´m thinking to order the suspension bar set form RRM.
    But will I feel a difference.
    What is the exact sense of this bars?
    I know that the car will be stiffer, but what is the effect of it??
    An other question.
    I know where the front strut bar and the lower truss bar are install, not how, but where.
    Just the oder bars?
    Where are the used??
    http://www.roadracemotorsports.com/stor ... ge&pID=200
    From the top to the bottom of the pic.
    1. Strut bar
    2.Lower truss bar
    3. ???
    4. ???
    Can anyone explain it for me, please??
  2. Evolve
    The other two items are the Upper Rear Strut Bar (that connects directly to a mouting point in your trunk area) No welding needed. Increases rear-stiffness and added with the anti sway-bar can give the car a more predicatable and direct feel when cornering hard. Even more responsive if your car is lowered. :D
    The two bars that are identical are the lower Tie Bars. They mount directly to mouting points underneath your car and further tighten the suspension. You'll notice the stock tie bars are flimsy-and weak looking.
  3. mpirklbauer
    Oh, thanks for the quick answer.
    But I can´t imagine where to fix the 3. bar??
    Do you have a pic??
  4. Evolve
    i have a picture of it installed on my car. I can't access my account from work but it literally goes straight across your trunk area from one side of the wheel to the other. If i remember i'll post a pic. It can be seen from the trunk. not underneath the car like some of the other suspension parts
    It goes inside the trunk between the springs/struts area.
  6. jacob1bc
    jacob1bc Well-Known Member
    here's a pic of what there talking about
  7. Evolve
    thanks jacob.
    as i suspected, i forgot to post a pic. now im at work again. :alien:
  8. Redline1
    i wanna get the upper strut but that means i got to push my subs up
  9. mpirklbauer
    Thanks, but I think that won´t be so god.
    I need some room in my trunk and I think with that bar I will lose much space to the top.
    What size are the bolts on for the sturt and the lower truss bar??
    What diameter have the bars??
    Looks a little bit weak!
  10. Evolve
    i fit my hockey bag in there all the time. i play all the time. what kinda room do you need?
    im not questioning you, im just curious. Cuz the bar sits sliiiiiiiightly above the trunk surface. and it sits pretty much all the way towards the back.
