Deciding on amplifier
Discussion in 'Audio, Security and Electronics' started by spiderman671, Jun 24, 2008.
Which amplifier?
  1. Profile AP2000
    0 vote(s)
    0.0%
  2. Kenwood KAC-7204
    0 vote(s)
    0.0%
  1. spiderman671
    Here again with another poll... This time I need help choosing the best amplifier to go with my sound system.
    Subwoofers 2x 12" Kicker CompVR0124
    12" subwoofer with dual 4-ohm voice coils
    power handling: 50-400 watts RMS (200 watts per coil)
    800 watts peak power handling
    frequency response: 25-500 Hz
    sensitivity: 86.7 dB
    More Info: http://www.crutchfield.com/S-AvmWQLXJEq ... &s=0&cc=01
    Which amplifier would be the best?
    Profile AP2000 2-Channel
    2-channel car amplifier
    320 watts RMS x 2 at 4 ohms (480 watts RMS x 2 at 2 ohms)
    960 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
    variable low-pass filters (50-250 Hz, 12 dB/octave)
    variable bass boost (0-12 dB) at 45 Hz
    variable subsonic filter (20-50 Hz)
    wired bass level remote control
    stereo or bridged mono output
    Tri-way capable (Tri-Way crossover required)
    preamp- and speaker-level inputs
    preamp outputs
    fuse rating: 25A x 4
    More Info: http://www.crutchfield.com/App/Product/ ... 000&tp=115
    .... OR ....
    Kenwood KAC-7204 2-Channel
    170 watts RMS x 2 at 4 ohms (250 watts x 2 at 2 ohms)
    500 watts RMS x 1 bridged output at 4 ohms (4 ohm stable in bridged mode)
    CEA-2006 compliant
    high-pass (12 dB per octave) and low-pass (24 dB per octave) filters variable from 50 to 200 Hz
    variable bass boost (0-18 dB at 40 Hz)
    cooling fan
    MOSFET power supply
    speaker-level inputs with signal sensing turn-on
    preamp-level inputs and outputs
    fuse rating: 40A x 1
    More Info: http://www.crutchfield.com/App/Product/ ... 113KAC7204
  2. spiderman671
    I am also open to other suggestions or other amplifiers that you recommend that may be better than the two posted.
  3. lordayne
    lordayne Well-Known Member
  4. spiderman671
  5. SoflaGTS
    SoflaGTS Well-Known Member
    lol i have one cvr and neither of those would work bro
  6. spiderman671
    What do you mean neither of those won't work, which ones?
  7. mancer2
    mancer2 New Member
    personal b/c you got dual 4 ohm coil i would run 2 mono amps like the kicker 300.1 or you can get i mono amp that is 1 ohm stable that is big bucks . if you go with a 2-channel amp it would have to be pretty powerful to push two subs . if you could i would return the subs and get dual 2 ohm coils so you can just get one good mono amp like the mtx 5601 from sonicelectronix.com . that is just my 2 cents
  8. spiderman671
    thanks for the help guys...
    question... if I switched the 2 12" Kicker 4-ohm voice coils to 2 12" Kicker 2-ohm voice coils, which of the listed amps would be the best to power the 2-ohm voice coil subs?
    and again, taking suggestions for other amps that you think would be better to power the 2-ohm voice coil subs.
