well i was planning on fiberglass but frankly i dont have enough time to do this so i will use a regular dual twele inch enclosure and i will place a piece of wood in front of i that cover the entire middle hole in the trunk to act as a wall so to speak. then the spare tire will be left and the stock cover will be removed. i will elevate a piece of wood to cover the entire middle area of the trunk and then i will cut a mitsubishi logo into it and fill it in with plexiglass. then this will be lined with blue LED stripping so it will iluminate blue the hinges will be installed in order for access to the spare then on each side where it dips in will be a piece of wood acting as a wall the left side will me my 4 channel amplifier and it will be sunken in and blue LED strips will again be placed around it on the right there will be 2 or 3 power capacitors that will illuminate blue but once i have my mono block amplifier these will be moved to a new location in the trunk. basically this will be a zero wire install you will see absolutely no wiring and i mean that all i need now is to go pick the wood up and then i am set to start but heres the "MAP" i drew out for it lol its 3:22 and i was laying in bed thinking about this and i had to atleast draw a diagram so i did and i wanted to share but of course install pics will be in order also im contemplating what color to upholster the wood i was thnking either white or black they would both look amazing heres the pic
Either get rid of 2 of those Mitsu logos to keep it simple or make the top 2 logos smaller and one big one on the carpet of the trunk.
lol well there really isnt enough room to do the top ones so im just doing the floor one but yea prophet if you wouldnt mind helping and i need help finding plexiglass and i need a jigsaw
Pretty sure you can get plexiglass from Home Depot. But ya i'm willing to help early to mid saturday, got a party to go to later saturday night.
I have to admit your idea is out of hand. HOwever, i see it as impossble, due to the fact that you will never be able to remove a spare with that much stuff holding down the trunk floor. IT doesnt fold or bend, cuz its wood. Trust me, when i made my system, i had the same problems.
lol thats where a jigsaw and hinges come in hand. dont worry ill get this right and it will look amazing
