another weird question
Discussion in '8G Lancer - General Information' started by beard_irish, Nov 4, 2009.
  1. beard_irish
    beard_irish Well-Known Member
    When i roll up my driver side window, it makes a kind of popping noise when it seals at the top, does this happen to anyone else. and if so, is it something i should be worried about at all
  2. bambam
    bambam Well-Known Member
    it does to me and havent had any problems with it...had it for a couple months
  3. beard_irish
    it always happens when the driver window is the only one open, so i was just wondering if it was the pressure difference.
  4. total0wnage
    total0wnage Member
    sounds normal 2 me, my window actually used to make popping sounds when i roll it up, apparently the regulator is bad and was covered under warranty
  5. EngRWW33
    EngRWW33 Well-Known Member
    FYI... I had a popping when rolling up and down the driverside window and it would also rattle a bit. Ended up being a broke window regulator (or something). They replaced it free of charge in about 1 hr.
