amp install problem
Discussion in 'Audio, Security and Electronics' started by sunstealth, Sep 18, 2008.
  1. sunstealth
    sunstealth Well-Known Member
    i installed an amp for a subwoofer on my stock system, everything wired cleanly in the center console area, amp under passenger seat. I used a line out converter to transfert the high output signal to low output but i am now getting any positive signal from the LOC only ground and everything was wired according to the wirning diagram on the download section (rear speaker wires used). everything was soldered then taped over, could the LOC be defective or im just bad at it ? (the LOC ground is connected to the radio frame, i was now sure if it is proper)
  2. lancermike
    lancermike Well-Known Member
    the amp isnt powering??? if its not its the same thing that happened with my car u have a defective battery go get a low test done to check n make sure
  3. 4B12LancerGTS
    4B12LancerGTS Well-Known Member
    Hey whats up! I did a similar thing as well but i did not use the ground wire on the LOC i just cut that wire right off. It may work if you try it like that.
  4. sunstealth
    i will try cutting the LOC ground
    amp is powering , everything is pluged in nicely, just no signal coming from the RCA :?
  5. 4B12LancerGTS
    Remote wire? Perhaps?
