03 es
Discussion in '7G Lancer and older - Performance' started by zafoam, Apr 14, 2009.
  1. zafoam
    zafoam Active Member
    I have an 03 lancer es im wondering if i should turbo it or not. I think i could produce 200hp without going turbo for cheaper however im not for sure. if anyone could help this newb in need it would be appreciated
  2. ssp-turbolancer
    ssp-turbolancer Well-Known Member
    how do you plan on making your car 200 with out being turbo?
  3. zafoam
    that's kind of what im wondering if i could get there or if i would have to turbo it. most turbo kits are around four grand i can do it, but i really dont know which way would be cheaper and most likely safer in the long run.the more i look at it though looks like turbo is the way to go.
  4. ssp-turbolancer
    as long as you do it right, do ur oil changes and your routine maintenance on your car you should be ok with turbo. I know i could not boost more then 7psi without bigger injectors. i installed bigger injectors with a re tune and now i should be able to boost at 12 psi but im just fine with 7 psi.
  5. zafoam
    thanks a lot man. guess i better start looking at turbos. :D any suggestions besides rrm?
  6. ssp-turbolancer
    u could build one and i believe speed corps has a right up on it or you can goto turbokits.com
  7. zafoam
    k thanks a lot for the help. hopefully i will be doing a progress report about my car with a turbo soon.
  8. ssp-turbolancer
    sounds good
