I like to know if any one that owns a 02-03 es,ls,oz has had problems with their running lights or ac/heat fan. My right side running lights will not work you can replace the fuse and it will blow soon as you turn them on this has to be a wiring harnes problem. Yesturday my fan stoped working I hit the top of the dash and it came on then turned back off and now it does not work. will check the fuse to see if that is the case. :cry: If anyone has any info it would be very helpful :?:
Blowing the fuse would indicate that you have a short in the harness. Pull your radio out, and check the harness for bare wires in the area, or any rubbing of the harness against bare metal. The radio bay and heater/ac controls share the same area and harness (I am pretty sure), so I would start there, and work my way back to the fuse panel. Having a multimeter will help in the TS.
