Traction
Discussion in '8G Lancer - Performance' started by Coop, May 12, 2009.
  1. Coop
    Coop Member
    I drive a manual Transmission and I can never get a good start without my wheels spinning. I end up having to get it rolling and then go but i lose time and acceleration doing this. Does anybody have any mod ideas on how to get better traction for the start?
  2. bambam
    bambam Well-Known Member
    take off at a lower rpm...
  3. GiveMeEvo
    GiveMeEvo Active Member
    play with the cluch and gas as you are starting you will allways chirp them a bit. Their is no real way to tell someone how to launch well you can only practice
  4. lancer2quick
    Yeay, you really can't tell someone how to launch. I have a stage 2 Ecedy clutch in my R/A...and it grips hard. What I have to do is launch at arouns 2500 and then, instead of just punching it, I have to roll into the throttle. Its a pretty fast roll, about 1 second from when I dump clutch to WOT. Second gear is the same for me too...just a quick roll.
  5. Coop
    Coop Member
    ok ill just play with it a little
  6. EngRWW33
    EngRWW33 Well-Known Member
