Teins installed
Discussion in '8G Lancer - Suspension' started by BigSteve, Feb 23, 2008.
  1. BigSteve
    BigSteve Well-Known Member
    I just installed my tein s techs this morning.. i like them alot.. i just had a few questions though.. do i need to worrie about excessive tire wear? should I get an allignment in about a week after the prings settle? should I get a camber kit? how do i know if i need these things.. I was hoping some ppl on here had the s techs installed so they can let me know what I need to do.. ill post pics ASAP
    thanks.
  2. BigSteve
    anyone??
  3. GTS-SB
    GTS-SB Well-Known Member
    i got my S-techs installed about a month ago and got an alingment right after. i spoke to John from Speedcorps and he said the drop isnt as extreme so we dont need a camber kit. as for the tire wear i dont know. as of right now my tires are fine but i dont really have an answer for you. post pics soon!
  4. XxLaNcErGTSxX
  5. GTS-SB
    before
    After
  6. starwaiting
    starwaiting New Member
    nice drop~~ :D
  7. SpeedI2acerX
    SpeedI2acerX Active Member
    hey if its not too much to ask can you take a pic of the rear wheel fenders? im thinking of lowering mine too but i have a wide rims/tires set-up. thx
  8. chetman7
    clap clap clap
    its about time u got those on steve
    get an allignment after a couple of days.
    you don't need a camber...but if u see uneven tire wear....go pick some uip....there not that much money...around 80 bucks especially wen tires are mad money
  9. 5th
    if its not a serious drop then you really dont need one
    when i installed my springs it was bad so i didnt really need an alignment
    but usally when you do a drop its always good to get one just to be on the safe side
  10. BigSteve
    thanks fellas.
  11. Invincible
    Invincible Well-Known Member
    Very nice, i think so far this is the drop that i love the most, only thing we need to know is, how do these ride? handling?
  12. GTS-SB
    the ride is great! not bad at all. i would highly recommend the Tein
  13. 5th
    a lower center of gravity is always good in the nieghborhood
  14. bras_33
    If you do not get a proper alignment, your tires will wear out quicker. camber kits are needed for extreme drops, usually anything from 2"
    THIS TOPIC HAS BEEN DISCUSSED BEFORE, PLEASE DO A SEARCH BEFORE POSTING.
  15. GTS-SB
    YEAH!
  16. DirectorSe7en
    DirectorSe7en Well-Known Member
    That looks damn good.
  17. grizbone
    grizbone Well-Known Member
    I always thought the rule of thumb was to give the springs at least a week, maybe two in order to let them settle and have the car aligned again. And I always did camber kits, tires arent cheap.
  18. bras_33
    especially low pro 18s
  19. 59vampire
    59vampire Member
    great info for a newb thanks
