So I know they have the VHT Nite-Shades spray can that seems to do a very good job, but then Lamin-X has a easy to use tint film cover kit. both seem to work and both seem pretty easy. the film kit is more expensive but im wondering if theres maybe a reason for that? plz help!
Film may cost a bit more because usually its cut to fit the shape of your tails like the ones from Extreme Vinyl. Either one will work i like Vinyl because its easier to remove and it gives a better smoked looked in my opinion. However, you will have wrinkles in the film having a heatgun or a blower dryer will smooth out the lines and wrinkles. Spray tint is nice and easy however you do need to remove your tails and paint the inside of the housing. However be careful with how much you use you dont want them being to dark and you dont want them being too light remember to do coasts then check to see if you have the balance right.
thx for that! i decided to go with the spray, ive seen it in action and it maintains a pretty good look to it.
