Question about Tein S Spring
Discussion in '8G Lancer - Suspension' started by NoFEAR, Apr 22, 2009.
  1. NoFEAR
    NoFEAR Active Member
    Hi tuner~ i am a nub for tunning...
    however i have a question for tein s spring
    is it tein spring bad for gts shocks?
    if it is what spring u guys recommend to get it...
    i want the safe shock and noticeable drop...
    another question.
    i have gts cvt. am i able to install blow off....
  2. vmo91
    vmo91 Well-Known Member
    no it will mess up your stock shocks
    you will need to get a chamber kit
    any drop more then 1.5 inches you need to get a chamber kit
  3. NoFEAR
    what is a chamber kit?
  4. vmo91
    they help probably align the front of your car if you go to low
    here are the ones rrrm makes way over priced i think tho
    http://www.roadracemotorsports.com/stor ... ucts_id=82
    i must request the G.R.I.P rrm springs i heard they ride amazing, and they will not require a chamber kit , they will only need an alignment after they are installed
  5. BlueBallLancer
    BlueBallLancer Well-Known Member
    RRM springs are exactly the same as Progress tuning springs which are cheaper too (google it) I had the Tein Stechs..holy crap i was literally a rough rider.
    I have an RRM Camber Kit for sale $60, RRM exhaust $230, INjen cold air intake $200 all shipped
  6. BlueBallLancer
    you need a camber kit regardless of the drop because the lancer stock bolts cannot be modified for different camber degrees
  7. NoFEAR
    was it tein spring give u really bad ride?
    if i decided to buy rrm spring then i don't need a chamber kit?
  8. jarol220
    jarol220 Well-Known Member
    it's called camber it is how far your tires go in and out so if the tire looks like this / <- it is positive camber and \ <- is negitive camber. I don't think that it will really mess with the way your car rides like on bumps and stuff but from what the other guys are saying it will mess up your alignment so your camber caster and toe could change.
  9. JDMFanatik
    JDMFanatik Well-Known Member
    when you lower your car, you get negative camber. to back up jarol220 with his explanation, here's a visual one.
    if you get one of those unadjusted camber, your tires will look like this:
    and you'll end up spending money to replace these tires. therefore, you use a camber kit to prevent all these problems. hope that helps.
  10. kennyjai
    kennyjai Well-Known Member
    negative camber is good for handling in FF car =)
  11. JDM FLOW
    I have the TEIN S-Techs and they not that bouncy and yes you will need a camber kit.
    As for the blow off valve [BOV] you will need a turbo for that due to only turbo cars use bov.
