Power loss
Discussion in '8G Lancer - General Information' started by AtomicQtip, Mar 4, 2009.
  1. AtomicQtip
    AtomicQtip New Member
    Lately my 08 lancer has been driving like ass. It doesn't have the pull above 3000 rpms that it had and it is more likely to bog down in the low rpms. There is also a definate change in exhaust/intake/engine noise right around 3200 rpms that was never there before. It almost sounds like a have an intake which is kind of weird because my car is completely stock. I have only 20000 miles on my car I don't think that stuff like this should be happening so early in the life of the car. Anyone have any ideas what it could be? Any help is appreciated.
  2. skullpr
    skullpr Well-Known Member
    no clue my suggestion is take it to your nearest dealer and have them check it out....welcome to LT!!
  3. olvhec
    olvhec Well-Known Member
    Have you checked your air filter, it might be REALLY dirty. And are you carrying more weight than usual. Even with having an extra person or two I can feel a big difference. Keep in mind thats about ~300 lbs probably more for two people, but the sounds difference shouldnt be to much if that were the case.
  4. brads09lancerGTS
    brads09lancerGTS Active Member
    Check the air filter. Also, are u due for an oil change? Our cars are always peppier after an oil change and bog down the closer they get to needing an oil change.
  5. AtomicQtip
    Problem solved. It was definatly the airbox not being closed right. It appeared closed and good but it was the two damn hooks on the bottom of the box. One/both must not of been on right. My baby is back to how it should be. Silly me not noticing the clips on the bottom. I even checked the airbox twice after the problems started. :cheers: :cheers: :cheers: :compress:
  6. leeminho86
    leeminho86 Well-Known Member
    Haha nice, easy enough fix :thumbup:
  7. eKtor
    Thats exactly what i was gonna say.. for some reason they popped out in my car too... weird..... 8O
  8. skullpr
    what im trying to figure out is how do you lose power with more air flow?? if the airbox was a bit open it would breath more...wouldnt it?
  9. LancerRA09
    LancerRA09 Well-Known Member
    I believe the air-fuel ratio would be off, i may be wrong tho.
  10. skullpr
    but if that were the case when you put an SRI or CAI which both breathe better the ratio would also be in play...wouldnt it?
  11. LancerRA09
    It will increase your air flow yes, but enough that the ecu could adapt and equal it out. An open air box supplies a lot of air.
  12. LancerRA09
    Plus your main air will bypass your MAF sensor, thats prolly mainly where your power loss come from. Your MAF sensor said somethings wrong.
