finally found a way to use my hid with out being on all the time,all you need is a 30amp relay.and hook it up to your side markers...that is it bro,f__K DRL..
tat,i'm telling you bro,took me about 30 min to do it,if somebody want to confirm,well let me see if somebody take a pic will my car is running.. i'm so fu--Ing happy,I forgot, i installed my sri today also... :lol: :twisted: :bounce:
Im willing to give it a shot. How and where to you put the amp? In the fuse box? If so, where exactly man.
yea serious give us more info. you p.r guys always leave us out on this valuable info. take pics and what to do. people want to do this. dont create all this hype if this is fake
fake?like when i said that ralliart springs fits man cars...come on dude,firs need a 30or 40 amp.relay then find the combination,diferent rileys dif.wire color,one wire for the battery + terminal,one to the +on your hid cable, one goes to the ground,one to the blue wire of the side marker thats you remote wich will turn on your hid,since it's a side marker you will only turn it on during night time [/quote]
fake?like when i said that ralliart2006 springs fits 2008 ...come on dude,firs need a 30or 40 amp.relay then find the combination,diferent rileys dif.wire color,one wire for the battery + terminal,one to the +on your hid cable, one goes to the ground,one to the blue wire of the side marker thats you remote wich will turn on your hid,since it's a side marker you will only turn it on during night time [/quote] remember the black on your hid goes to ground {-}
this is confusing since you hook up the relay to the side marker, so does this mean everytime you use your turn signal your headlights blink ??? confused on what you did and how it works??? i would be able to understand if you hooked them up to your parking lights but not turn signals.....
let me see if i can explain,, in your head lights in the bottom corner it's a little bulb ''parking lights''that when you turn you lights control half turn will come on,it has a black and blue wire.so with the white wire from your relay''that will be you remote to turn the lights on''to the blue wire on those lights;then if you have hid,use the red[+] wire to the blue wire in the relay,hook both hid red wires to the blue wire,then the yellow wire to the pos.+ battery terminal and black wire from hid and relay to groud[-] there is a wire on the relay that you donot use my was the red one,well i used a relay from pepboys $7.95. i don't know how else to explain so good luck bros.. :wink:
what you are doing is running the HIDs through the fog lights so to use your HIDs you would actually be turing your for light switch on?
No use your parking lights to hook to the relay. Not the turn signal. That way everytime you turn on you parking lights the HIDs come on. Most don't use just their parking lights so it works out for most.
Mera! See if you can uploads some pics bro. I'd like to see what it looks like. Por fa, bregate ese caso.
Ok. If it can be confirmed... let's see it. I think we are all asking for pictures or some other way to visualize what is being said here. e.g. I could, one day, say that I have a sure-fire way to win the Lotto everytime I played, but w/o proof it's just... :roll:
