So I've been researching sound systems and I'm wondering if this set up is going to work. This is what I have so far is: Pioneer HU Pioneer iPod Adapter Do I need this? Pioneer Bluetooth Adapter Do I need this too? PAC Steering Wheel Adapter Will this work? Pioneer Amp Pioneer Sub Pioneer Speakers I'm going to be using the Metra Dash Kit and maybe also the Metra Steering Wheel Adapter if the one above doesn't work. Is that set up going to be okay and compatible? I don't use Satellite radio so I don't need the adapter for that. The current sound sytem will be taken out and replaced with everything above if this works out. I'm mainly wondering if all of this will be able to connect to each other and if there are any changes I should make. For the steering wheel, I'm mainly looking to be able to change the volume since the screen is touchscreen. Hope that's enough information. Thanks in advance! JP
The PAC-SWIV won't work. That is if you are adding a audio/video source to your stock radio. You are replacing your radio so you want the SWIX.
