My A/C dont work...
Discussion in '8G Lancer - General Information' started by GODZILLA, Apr 18, 2008.
  1. GODZILLA
    GODZILLA Well-Known Member
    i just noticed my ac not working today. i rarely use it because im trying to save some money on gas but today it was too hot not to use it. When i turned the nob to turn it on, it didn't turn on... there was no air coming out at all and it was on high. so i dont know wats wrong with it and im just going to take it to the dealers...
    oh ya and is it going to be under warranty?
  2. RedStar
    Yea it should be under warrenty. Take it in. Only thing that is not is wear an tear. Brakes, tires, ect...
  3. Redline1
    did you check to make sure that it was no the vents,. i turn it all the way on cold and max ac comes on as long as your not set in defrost, but yes under warentee
  4. vik2rius
    vik2rius Well-Known Member
    i had the same problem last summer about 3 months after I got my lancer problem was the ac blows hot air, they tried to blame it on my SRI...which was BS, cuz i dont c the connection...
  5. Bryn1987
    Bryn1987 Well-Known Member
    u should be using ur AC if you're going above 40 mph... it's been proven over and over again that u save gas by using AC at mpg above 40 mph, because above that speed you are getting so much wind drag that u end up using more gas to compensate... just thought i'd inform you... u save gas by using AC ;)... if u don't believe me look it up... it's all over the place, and it's been tested way more then just once :p
  6. GODZILLA
    alright well im going to take out my sri b4 i take it to the dealers and thanks for all the info bryn1987.[/quote]
