i have an 03 es is there any lip kits avaliable for it all i seem to find is for the evo 8 would it be an easy thing to do to put evo front and rear bumpers to put that lip kit on?
I can 100% tell you there evo rear bumper and fenders do not fit a lancer. Im not to sure on the front end. The only things I know for sure that fit on lancer from the evo are as follows. Front doors Trunk Hood (wont look right) turbo setup (with the exception of the manifold and 15 psi spring in the wastegate actuator) door windows Steering column/steering wheel All interior gauge cluster eerrrhhmmm...this is from JRR over on another forum "i know there is a compatability thread for lancers and mirages, but nothing for the evo. there are S"OME parts that fit, but most do not. here is a list of what i could come up with that works/dont work with a little explanation. THIS IS A REFERENCE ONLY, I DONT TAKE ANY RESPONSIBILITY IF SOMETHING IS DONE WRONG OR NOT INSTALLED PROPERLY! WORKS: turbo - will fit with custom 4g94 mani (a few mani's floatin around the threads here and speed corps used to make them) stock intercooler and intercooler piping - for the intercooler,remove the front rollers and use the 2 outside bolt holes. for the piping, holes are there and threaded already if i rember correctly. aftermarket intercooler and piping - depends on size but will probably reqire cutting stock bumper to make fit for the intercooler. for the pipes may require like the AMS small battery kit (ie. the greddy pipe setup or AMS). the set of injen pies will work as well with the stock evo battery tray. here are some pics and some info on what to do to make them fit like a charm! http://forums.evolutionm.net/7549710-post230.html battery tray - right by where the stock air cleaner would sit by the transmission mount on the drivers side. the holes are there and tapped already radiator - heard that it fits but dont know the up/downsde to actually running it. trunk - uses all the same bolts and lock assemblies. nice if you find an evo wing and dont want to fill the holes in your trunk form a stock lancer trunk with factory spoiler. radio relocation kit - most of you know this already as for we have gauges where the stock radio sits, or are running a dual radio setup. gauge pods - a pillar, steering column, radio relocation (see above). basically if you can mount a gauge in an evo you can mount one in a base model. turbo timer w/ harness - splices right into your ignition system with a harness from hks or others. spedometer cluster - direct drop in from where ours sits now. 399 mass air flow sensor - works if you know the values tobe put into ecuflash and you have the cable to reflash the ecu front shock and struts - direct bolt on from what i hear. not sure of the benefits but have heard they do work. from 03lancerES: the only way for the ES (except for the 06 style es's that use the same suspension as the oz's and ralliarts)models to utilize this is by using the front strut mount from an OZ which is bolt on then you can bolt on the evo's evo 8 ecu - requres a reflash cable, ecu flash and a lot of patience. once in and working opens up tuning capabilities for turbo setups. stock and most aftermarket down pipes - works with evo turbo and o2 housing setup. stock interior - seats, door panels, center console, evo 8 steering wheel, dash, trim, vents(if i missed something please let me know) steering rack - tighter ratio evo mr aluminum roofs / AMS Carbon Roof - Quote: Originally Posted by EricJ@AMS Yes our CF Roof definitely fits all 02-06 Lancers. evo rims - can be used on lancers with a 5 lug hub or have done a 5 lug conversion rear calipers/rotors - work on disc brake models body trim - posted by turbotime - can mount or be mounted to the lancer chassis glass - posted by turbotime - includes mirrors and all glass are swappable front strut bars - Quote: Originally Posted by link62 front strut bars will fit Quote: Originally Posted by quikkstylez is this confirmed? Front strut bars will fit an 05 lancer? Quote: Originally Posted by turbotime yes confirmed hood latch - uses all 3 of the same bolt holes as the base lancer. works great if you have done an evo 7 conversion to the front and want to put some nice mesh in hte grille. evo fuel pressure regulator - will have to bore out stock or aftermarket fuel rail a bit to make it fit. Evo MR Vortex Generator - if the roof will fit this will as well. can get authentic mitsu or aftermarket."
I know Accolade has one, just not sure if they still ship to the US or not...they shut down their US facility b/c of the economy I think....at least that's what I've heard.
