I just bought lamin-x tint, tried putting it on, and by far was so pissed off i just did a horrible job and left it. Does anyone on here have lamin x on there tail lights instead of spray or is it just me cause i need major help.
I ended up looking at a tint film for the taillights and for the curves and crap it said heat it up with like a hair dryer so that it conforms better but honestly i didnt like it at all how it looks because the film does warp a little so i ended up just taking it right off.
I've heard mostly bad things about blacking out your tail lights with film. VHT is just so much easier. A friend of mine and I sprayed one of his stock tail lights. I think we put 2 maybe 3 coats on it, and they were black. Just sand it down to a rough surface, and then spray the VHT. You can put a clear coat over it if you like, but you don't need it.
The only thing is I need to have a way to take off the VHT if I would get pulled over. I did the film because of that and it looks awesome except if you get really close and see how bad corners are haha. Ill post pictures later this weekend.
i read a thing on using a light sandpaper and wet sanding the tint and then using a buffer to redo the shine
Ill look that up later. Im going to wait probably a month, if no problems Im just going to paint them with my RC tint spray I used for side markers and reflectors
