Installed HIDs but...alignment issue.
Discussion in '8G Lancer - Customization' started by thetaxguy, Oct 30, 2007.
  1. thetaxguy
    The driver side beam is too high now. I already checked the bulb and it's installed correctly. Does anyone know how to adjust the vretical alignment of the driver side headlamp?
    Thanks.
  2. kinkbmxrydr
    did you install the hid bulb correctly, i remember when i had hid's in it was a bittttch to install becasue such tight fitment. Play with the bulb and move it around thats how i did it, and also make sure if you have an HID kit that the bulb that has the long stick on the bulb is either close or on the bottom
  3. Automoglow
    What did you do to bypass the DLRs?
  4. thetaxguy
    I have not addressed the DRL issue just yet. I spent most of the time removing the bumper cover and installing the ballasts in the stock location under the headlamp housing. Maybe I'll get around to it this weekend.
  5. thetaxguy
    You no longer have the HIDs installed? Is there a reason?
    Thanks.
  6. kinkbmxrydr
    Drl issue i cannot stand the flickering but its cool though
  7. spunx021
    when I put the HIDs on my ride, I didn't have this issue (alignment) I guess I just lucked out, but yes, the DRL sux, my headlights have to be on all the time or else it'll start flickering, (which also looks cool when ur parked at night, they look like strobe lights, hehehe)
  8. kinkbmxrydr
    yea my friends thought its soo cool and we could have our own party lol
  9. thetaxguy
    So I guess what it comes down to is no one knows how to adjust the vertical throw if the headlamp...since that was my inital question and all. :wink:
  10. BLACK-GTS
    BLACK-GTS Member
    I have the same problem i have no idea why>>>>> :?:
  11. Lancer-Randy
    i think theres a way to get rid of the DTL check the owers manuel i think i saw a form on them on here. . .
  12. thetaxguy
    Nope. Can't find it. Would you be able to give us a page number? Thx.
  13. Mada
    Mada Active Member
    did u get the 1200k?? because the i had those on the lancer and i had the same problem.. i switched over to the 8000k and they fit perfectly
  14. kinkbmxrydr
    ^^^ dang ur car has a lot of blue
  15. topher
    topher Well-Known Member
    ^^^ lol u said dang!
  16. thetaxguy
    Nope. I have the Rikken Sport 6K HIDs. It's wierd b/c it's only the driver side. Oh well, when I take my car in for it's first oil change I'll have the dealer realign the headlamp.
  17. BLACK-GTS
    BLACK-GTS Member
    i installed my HID with relay hardness and i have the same problem that the driver side its high but i think is because the relay so it looks like the relay gives more energy to that side because the driver side looks more shiney. Does someone know how to put the same volume of light to both sides?
  18. Guest
    any updates? did ya get ur alignment issue handles with the lights?
