I Need Ideas....
Discussion in '8G Lancer - Customization' started by LuvMyLancer, Apr 19, 2008.
  1. LuvMyLancer
    LuvMyLancer Well-Known Member
    I bought headlight strobes and as it turns out, there's no way to take the headlights out of your car without removing the bumper, and that's just WAY too much of a job....
    So... any ideas on where I should put the headlight strobes??
    Or if anyone knows how to put strobes in WITHOUT removing the headlights... that'd be awesome.
    how about the fog lights?
  3. Texas Aggie
    Texas Aggie Well-Known Member
    how bout behind the grill?
  4. LuvMyLancer
    I dunno about the fog lights, just because my underglow is crazy and does tons of different flashing/colors/dancing on its own... I dunno if that'd be too much stuff goin' on around the bottom of my car.
    As far as the grill goes... these strobes were made specifically for going inside a headlight, do you think if I put them in the grill any rain/water will short them out... ??
  5. Texas Aggie
    Oh ok...not sure about that. try contacting the manufactorer or something. or someone on here will prolly know
  6. KRU
    KRU Well-Known Member
    u can take ur bulbs out.
    drill a tiny hole for wires.
    insert strobe in2 opening where bulb mounts.
    run strobe wires thru sm. hole drilled.
    seal hole with silcocone
    connect wires
    reinstall bulbs
    and
    wha la
    any thing is possible.
  8. KRU
    can u post a pic or link to the style u have.
    I think I have a better understand now. Ur reply posted while I was typing my first.
    I just wanna make sure.
  9. LuvMyLancer
  10. Texas Aggie
    you're like a damn wizard or something
  11. Slickghost
    Slickghost Well-Known Member
    He's a SUPER wizard.....
  12. KRU
    u guys crack me up, but ty!
    Ok I looked at the link and yup just what I thout after seeing ur post.
    Ok, well u have to drill a hole in the head light housing from the top if you
    dont want to take the head lights out and
    do it from the bottom.
    any ways
    drill hole that will allow strob to fit thru
    be fore so remove bulb for access into headlight
    create a catch to redirect shavings out of the head light
    u can use a paper towel tube cut in half or less long ways
    then insert thru bulb area.
    this should catch most of the shavings.
    if u can tape catch in place then use ur vac hose
    attachment and turn on.
    this will help catch over 95% if done right
    ok
    after all that
    drill hole
    clean out headlight
    insert strobe
    connect wires
    test
    seal with silicone
    re-install bulb
    thats that
  13. bras_33
    Damn, KRU...brains and a pretty face? a double threat!!! :D
  14. KRU
    ^I feel the same way about the wife. TY man.
  15. blk_out_gts
    blk_out_gts Well-Known Member
    wow i just saw this and no offense to kru but youd think that more of you would know how to do simple mods like this... and before someone asked what kind of mods ive done i dont have anything crazy dont cuz i worked my but off to get the car so moneys a BIG problem....
    anyways sorry bout that well if you dont want to do want kru said and you just want them on the car but not necessarily in the front you can always put them in your reverse lights for fun when someone is tailgating you! lol
  16. Texas Aggie
  17. LuvMyLancer
    So, I decided to take the easy route and put 'em in where the turn signals are.
    I figure since they'll only ever be on when I'm at shows/parked somewhere, and it's so easy to take the turn signal out and put the strobe light in there... makes sense, and its super bright in that spot.
    Then when I'm done showin' them off, all you have to do is take 'em out and pop the turn signal bulb back in.
    Easy as pie and no drilling to be done!
  18. Bryn1987
    Bryn1987 Well-Known Member
    u gotta remember to try to do it on a day w/ low humidity and make sure u seal it really good, or else u'll get fog inside ur headlights :(
