I need bigger injectors
Discussion in '8G Lancer - Performance' started by lancerexgt, Apr 30, 2009.
  1. lancerexgt
    lancerexgt New Member
    HI,
    I own a 2008 Lancer 4B11 2.0L MIVEC (non-turbo). I'm having it
    turbocharged
    so I need bigger injectors. Please help where to buy..
  2. SeRious08
    You do NOT need bigger injectors unless you are doing the tuning for it. Try adding a fifthinjector like the other kits. If you absolutely want larger injectors, just swap yours out with the RA or Evo injectors.
  3. lancerexgt
    so evo x injectors will fit to our engine??
  4. RALLIART
    yes
  5. lancerexgt
    Thanks....
  6. grizbone
    grizbone Well-Known Member
    I sense a, "how do I rebuild my engine?" post coming soon.
  7. LancerRA09
    LancerRA09 Well-Known Member
    Yup, he's gonna pump more gas then his pistons can handle and fry his rings.
  8. goof
    goof Well-Known Member
    +1 i do recromend tho that u run on really low boost for a while if u do go turbo
  9. ThunderOZ
    ThunderOZ Well-Known Member
    Well he can always scale the injectors down to suite his needs if they're too big.
  10. SeRious08
    Thats all part of tuning.
  11. grizbone
    this is true
