if i were to get these ddm HIDs : http://www.ddmtuning.com/index.php?p=product&id=102&parent=85 would i have to leave them on all the time if i didnt get the DRL relay bypass harness?
the lights will always be on as soon as you pull down the handbrake while having your car on without the bypass. people were having problems such as flickering and one side not turning on at times. its best to have Jrox's DRL bypass harness with any hids.
^Thanks for recommending my product! Without the DRL Bypass, you will have to leave your HID lights ON 24/7 to avoid the HID Flicker--which damages your HID Ballast & Bulbs. However, if you install a DRL Bypass, you will be able to turn them ON/OFF without causing harm to your HID kit. Check out my sig for more info.
