HID lights
Discussion in '8G Lancer - Customization' started by spawn, Apr 9, 2008.
  1. spawn
    spawn Well-Known Member
    i recently purchased this HID kit on ebay.. http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0221473501
    well i tried to read the instructions and couldnt understand so i looked around the forums and i saw that you have to connect 2 wires to the battery but my kit does not have that or a relay.... so do i have to buy this or how to i install them?
    thanks
  2. Bryn1987
    Bryn1987 Well-Known Member
    i thought the lancer's were 9007... u bought 9006, u sure u have the right ones?
  3. spawn
    yaaaah im 99% sure they are 9006
  4. pimpinfern
    pimpinfern Well-Known Member
    they are 9006, we even have a faq on it
  5. kennyjai
    kennyjai Well-Known Member
  6. faracinman2
    faracinman2 Well-Known Member
    Some of the cheaper kits don't come with the relay. What you basically have to do is take out the stock bulb and unhook it from the stock plug, then just plug the ballast directly into the stock headlight plug and then plug the bulb into the ballast, then put the bulb in the headlight housing and then mount the ballast. It's pretty simple, simply plug and play. I don't have the relay on mine but I ordered one, its another safety precaution so it doesn't short anything out. Also, it helps make your lights not flicker if they do, because they have a direct power source from your battery. Another reason for the relay is to help solve the DRL problem. Hope this helped.
  7. JDM FLOW
    My suggestion is when buying HIDs, get one with a delay.
  8. kennyjai
    you mostly only need a relay for ur low beam cuz of the drl... the rest is fine without relay
  9. MXlou
    MXlou Well-Known Member
    oh really? where you come up with that one captain obvious?
  10. spawn
    ooh ok thank guy where can i get a relay and what kind do i need?
  11. Dukekid0987
    Dukekid0987 Well-Known Member
    honestly i got the same kit and i dont have a relay i just leave them on 24/7 which doesnt effect me or them at all. because mostly ohh H I D kits are the same. just plug them up like someone said ^^ there and they'll work just fine thats just me though bets buying and going through all the trouble of a relay :wink:
