HID lights pointed down
Discussion in '8G Lancer - Customization' started by BigSteve, May 21, 2008.
  1. BigSteve
    BigSteve Well-Known Member
    i installed my HIDs and it seems and looks like my lights are pointed more towardthe ground... anyone else have this problem?
  2. BigSteve
    what im asking is, if anyone knows how to fix this problem?
  3. RedGalant2k1
    There is headlight adjuster screws, usually a torx screw, possibly a regular phillips head screw that can adjust side to side and up and down.
    Kinda like this (note: picture is NOT of a Lancer headlight)
  4. eKtor
    i had that same problem... the problem was that the o-ring that is in the hid lamp was too thick and it wasnt fitting right.. can you actually SEE that its correctly installed (the 3 pins inside the socket)?
    i did it by hand at the beginning and thats why that happened... i took the o-rings off and problem solved...
    btw YES i know that the headlamp is not sealed and humity MAY fog the housing... it hasnt happened to me in 7 months so im not worried.. whenever it happens ill buy a thinner o-ring ;)
