HID lighting
Discussion in '8G Lancer - Customization' started by faracinman2, Apr 1, 2008.
  1. faracinman2
    faracinman2 Well-Known Member
    Is it just me or does the 08 stock headlights seem to project further then the HIDs, or so it seems they do? The HIDs are definitely brighter though... Or maybe I didn't put the bulb in right because it was a pain in the a$$ to get it locked in there.. Anyone else have this issue?
  2. Texas Aggie
    Texas Aggie Well-Known Member
    have you tried adjusting the light level? I don't have HIDs...just throwing it out there
  3. faracinman2
    i thought about that but i figured if the stock level is fine i shouldn't have to change it.... but idk i may have to
  4. azn_ghetto
    azn_ghetto Well-Known Member
    i think u should try and adjust the levels a bit, i know that there is a way 2 do that, but dont do it 2 much or else it will cause 2 much glare for oncomming drivers
    rite now i dont think that ur HIDs r causeing 2 much glare for other drivers but just be cautious when u adjust them
  5. Bryn1987
    Bryn1987 Well-Known Member
    actually, u can get ticketed unless i'm mistaken for having HIDs at stock lvl if they cause too much glare for incoming traffic... thats IF the stock lvl is causing too much glare...
  6. azn_ghetto
    technically u can get ticketed for having halogen housing with HIDs, any aftermarket HID kit that u put into stock housing is illegal
    cause halogen housing + HIDs = illegal
    projectors + HIDs= not illegal
    well at least where i live anyways
    but most cops dont know the difference, also its a new car so they dont no if they come stock with HIDs or not
  7. Karan
    Karan Well-Known Member
    Check your headlight aim, by adjusting the levelling screw.
  8. CLEANrideGTS
    I know that gettin the HID lights to lock in properly was a pain. If you look directly into the headlight housing(with the lights off) Look and see if the bulb is straight in the housing and not kinda crooked. I had that problem once but it wasnt too bad to fix, just some trial and error
    I have HID's in my foglights too and they fit like a glove, just perfect lol
