fender side marker (opening them up)
Discussion in '8G Lancer - General Information' started by sunstealth, Oct 16, 2008.
  1. sunstealth
    sunstealth Well-Known Member
    i know someone on here did it to put blue lights in them instead of orange, how did you do it, theyre all sealed up ???
    brute force or help from the holy oven ?
    (btw i want to blackout the light gray plastic backing)
  2. BlueDevilLancer
    if you're talking about inside, i want to do the same and also blue out my gauges. help teh newbs plz. much appreciated.
  3. nickbutterz
    nickbutterz Well-Known Member
    uhmm. no he means the side turn signal on your fender. idk im also curious about this... but im pretty sure blue is illegal and you need to have amber
  4. BlueDevilLancer
    my b. but yea it is illegal in probablly all if not most states. does anyone know how to change the interior lights by any chance? or guages?
  5. sunstealth
    ill keep the amber color, i cant stand blue lights on a car exterior (beside where they belong, like on police cars) i just want to paint the casing interior but seeing them from a closer perspective, i will just tint the "glass" part
  6. franchise5star
    franchise5star Well-Known Member
    i tinted mine :) they look sick. in order to take them out you have to remove the plastic covering thingy inside the arch of the wheel (where you put the mudflaps). once you took out the covering... you juss unhooked the side marker from the inside.
  7. sunstealth
    bahh youre complicating a simple thing,they can be removed simply by sliding them toward the door then toward you, pop theyre out!
  8. eKtor
    NO
    to take them out you just push the marker towards the front of the car and then pull out... extremely easy to take out..
    I opened them... they dont have a amber bulb.. its just an amber "cup" covering a regular white 194 bulb... i changed mine to White LEDs...
    Opening them is not liek the headlights, they are sealed good... i took a REAL thin flathead and started prying them lil by lil.... you have to be careful and have patience... i cracked the case of one of them... i then sealed them back with clear silicone...
  9. CLEANrideGTS
    so with the white LED's in the side marker EKTOR does it still glow orange or is it more white now.?
  10. bras_33
    I believe there is a "how-to" on this forum
