Ok so I just installed my back up and turn signal LEDS. Problem is when I tested the turn signals They are flashing faster than normal. It is a standard 7440 LED replacement for the OE ones. Same voltage but slightly higher wattage. Would this be the reason it is causing it to do this? Anyone else experience these problems?
Ok just found some info. I guess I am needing some resistors to trick the computer. Now the question is how many do I need? One for each bulb? What OHM rating should I use?
Thanks for the help guys lol. For anyone wanting to know this VLEDS has the resistors and it will tell you which ones you need for the different ratings.
