EVO X wheels would fit my lancer?
Discussion in '8G Lancer - Suspension' started by el lancer, Oct 27, 2010.
  1. el lancer
    el lancer Active Member
    Hi,
    I am getting a super deal (free) on three evo x wheels, I would only have to find one which I am already working on. I am pretty sure bolt pattern is the same but I am concerned with width since they are 18x8.5. I am concerned with rubbing. Anybody tried this set up?
  2. mitsuG
    mitsuG Well-Known Member
    what year is your lancer? 07+ ?????
  3. Jogenmaru
    Fit yes. But you have to get your fenders rolled a bit. If you are an 08+ the wheel pattern of 5x114.3 is the same. Its a bit aggressive.
  4. el lancer
    my lancer is 08 and I dont mind rolling the fenders
    thanks
  5. 1slowlance
    Yeah, you'd definitely have to get a fender roll, and they'd still be pretty wide. But, maybe you could pull it off. Get a nice drop and some nice tires and you're straight.
  6. el lancer
    my lancer is already dropped and if they rub well then I will sell them, and get myself some other wheels. We will see
  7. 1slowlance
    Good luck then. I bet they'll look good, the only issue I can see is them fitting, but shouldn't be too bad.
  8. Jogenmaru
    8.5 is the widest the tires can be. I think the evo x is 8.5. I have to research it a bit more. But they will fit with rolled fenders or wide body kit.
  9. jRox
    Actually, Evo X wheels can fit without rubbing depending on the tire size. If you go with the Stock X tire specs, 245/40/18, you will need to roll the rears, even at stock height. Some people have pulled off fitting X wheels except with 225's and lowered. Put simply, if you roll your fenders, you can fit the X wheels no problem. It really shouldn't be a deciding factor whether or not you want to keep these wheels--especially since rolling fenders is a simple job for a shop.
  10. el lancer
    Thanks for the info. I should be receiving them by Friday or early this week
  11. mitsuG
    i agree with jrox. tire size is a big factor with fitment issues.
  12. 1slowlance
    FITMENT!
  13. el lancer
    still waiting, they were supposed to be shipped on friday. I'll call my buddy to see whats up
  14. el lancer
    sorry I have not posted any updates, I recieved the wheels like a month ago. They are wide. I will test fit on saturday and post some pics.
  15. BlueDevilLancer
    get dat hellflush!!!
  16. 007
    007 Active Member
    post pics as soon as you get them on, i am curious to see how they fit will the rolled fenders.
  17. bras_33
    pics of my homies lancer with the X...tein drop, rolled rears...
