Enkei RSV
Discussion in '8G Lancer - Suspension' started by LancerGT17, May 5, 2008.
  1. LancerGT17
    LancerGT17 Member
    Just found another set of potential wheels:
    Car: 2009 Lancer GT
    Wheels: 18" X 7.5" Enkei RSV
    Offset: +35mm, +45mm (Both are available)
    Tires: 225/45/18 Kumho Ecsta ASX
    Drop: H&R Springs or RRM GRIP V2 (About 1.5" drop all around)
    Anyone know if these wheels will fit? and which offset? Thanks!
    JP
    bolt pattern?
  3. LancerGT17
    LancerGT17 Member
    5 x 114.3 =)
    i suggest the 45mm
  5. kennyjai
    kennyjai Well-Known Member
    i would go with +35 would be alot more agressive looking
  6. LancerGT17
    LancerGT17 Member
    Hmmm... 1 for each offset :?
    Whichever is least likely to rub has my vote :p
  7. LancerGT17
    LancerGT17 Member
    Another side note, my first wheel choice is +48mm, everything else is the same. Would those fit?
  8. kennyjai
    +45 is almost 100% no rubbing but +35 is more agressive people said that it wont cause rubbing but thats pushing it to the limit a bit so if u want safe go for +45
  9. kinkbmxrydr
    i actually have these wheels
    the offset is 45
    i have them in silver
  10. LancerGT17
    LancerGT17 Member
    Ok well my back up works then :p
    But what about ASA AR2?
    5 x 114.3, +48mm
    same tires.
    I'm having a hard time deciding which set of wheels is better. I prefer the ASA but not sure if the offset will work so the Enkei are my back up.
  11. kennyjai
    im pretty sure the ASA +48 would work... ive just checked stock offset is +46 so 2mm difference wouldnt matter
