Is it possible to install the EVO X internals in the Lancers engine? Ii´ve heard that Mitsubishi engines have select fitted bearings for the crankshaft and the rods. What exactly does that mean??
Yes and no. The internals are actually different. Yes they both are the 4B11 but different on the inside.
Yes I know that, but for example I will just change the piston to lower the compression it should work. OT: Hey SeRious did you dyno your car so far??
if you have the 2.0L I think the pistons and stuff fit but I'm pretty sure the 2.4 is different measurements. Someone correct me if I'm wrong?...
I´ve the 1.8L but the block and the head are the same as the one of the 2.0L. I´m thinking about going for the 2.0L internals, but I saw that the EVO has the same stroke,so I tough to use the EVO internals. Just the crankshaft and the rods, the pistons I want to use from the normal 2.0L, so the compression wont get lower. Is it possible to use the stock bearings for on other crankshaft and rods, or mean select fitted that the bearings must be selected with the shaft??
