engine face plate
Discussion in '8G Lancer - Customization' started by gwappix23, Feb 8, 2008.
  1. gwappix23
    gwappix23 Active Member
    i want to paint the engines face plate....
    questions....
    what paint must i use and what color...
    i got pics of my car... let me know...
    thanks...
  2. eTXlancer
    eTXlancer Well-Known Member
    you can use wat ever kind really. i got the "rust-oleium plastic spray paint" intended for plastic from home depot. i tried to match the color but it didnt quit work out. theres no need for high heat if your wondering because the cover dosnt get that hot or warm
  3. blacksheep818
    i used red caliper paint worked just fine you can get this at any autozone or pepboys
  4. spiderman671
    I just used high temp. plastic spray paint.
    Just cleaned it, sanded it, clean again, primer and then the base coat. Pretty simple
  5. GTS-SB
    GTS-SB Well-Known Member
    can someone post a how-to and some pics??
  6. BoostIt28
    BoostIt28 Active Member
    im doing mine this weekend ill post pics and a write up if no one has by then, and im using duplicolor
  7. delphium_
    delphium_ Well-Known Member
    Since its made of plastic theirs plenty of good paints out there, but i have my best results painting plastic with
    Krylon Fusion
    its made specifically for a good glossy finish.
    i did it on the lining of my paintball masks all the time looked pretty clean.
    just gotta make sure you dont over saturate it with paint, gotta have a good feel for the can.
    should look nice though
    Goodluck, let us know how it goes.
  8. chetman7
    ^^ quikl ot
    u a woodsball player...or speedball?
  9. gwappix23
    so its just ready to go...
    no sanding or anything??? like
    what the guy in a few previous threads said???
  10. bras_33
    For the best results, light wet sand first, paint, dry, wet sand, paint again. Its that simple.
  11. gwappix23
    /\ for sure thanks man
    /\ Not a problem, thats what I do-TheGoderator
  13. delphium_
    i used to play speedball,
  14. Ironballz
    Ironballz Active Member
    Someone suggested using vaseline on the words/logos instead of taping them then you can just wipe it off when you're done. I haven't tried it myself yet though.
  15. GODZILLA
    GODZILLA Well-Known Member
    ^^That sounds alot easier if it works.
  16. chetman7
    i used to play speedball,[/quote
    thats sweet...I played for about 5 years. I"m actually in the process of selling my gear to get money for my car lol....buy my ego
  17. JDM FLOW
    I play speed-ball and woods-ball.
  18. chetman7
    FLow....buy me ego...so i can buy stuff for my car :D
