do these cause CEL?
Discussion in '8G Lancer - Performance' started by aznboiultra, Dec 27, 2011.
  1. aznboiultra
    aznboiultra Well-Known Member
    Does crankshaft. light weight fly wheel,forge piston cause CEL? If not then where can i get them? or what else can i get that does not cause CEL?
  2. evilstig4b1
    evilstig4b1 Well-Known Member
    None of these will cause CEL. Good luck trying to find pistons.
    - after the install on the cams, you'll need to get tune.
    - lightweight flywheel (autocityimports.com).
    - dc headers, I heard leak real bad.
    - ***after every engine mod you add, you need a tune. Look into that first!
