For anyone interested in flashing your ecu yourself, I believe we could use this special cable in the link below to communicate with our ECUs after downloading the Ecuflash software to a laptop. Has anyone attempted this yet? http://www.tactrix.com/product_info.php?products_id=40
I previously owned a 2001 eclipse and used the same software and cable to flash my ecu when I turboed it . It wasn't listed as compatible with the eclipse when I did it before either. As long as it uses the same kernel software you should be able to communicate to the ecu with that cable. I am going to try it eventually but I just wanted to see if anyone else has attempted this before I stick my neck out.
