Cig lighter.
Discussion in '8G Lancer - General Information' started by OhMeOhMy, Jan 8, 2008.
  1. OhMeOhMy
    OhMeOhMy Active Member
    Ok, for some mysterious reason my cig. lighter in the front dash just stopped working. The one in the handrest is though.
    Does anyone know if this is covered under warranty?
  2. chetman7
    check the fuse
  3. playa213xx
    playa213xx Well-Known Member
    as long as you didn't mess around with any of the wiring in the car...i would say its under warranty...
  4. chetman7
    its a sign telling u to quit smoking
  5. Lancer-Randy
  6. tatsujo
    No need to jump to conclusions... seriously... if your car broke, i wouldn't say it's a sign to get off your butt and start riding a bike.
    Phone charging, adapters, power inverters..
    If nothing was messed with, I'd assume it's under warranty; take it to the dealer and have them check it out. What have you been using it for?
  7. OhMeOhMy
    Sorry, yes. I was using a power inverter for my laptop so I can charge it. I go on road trips every now and then. The last time I used it, it was about a week. Then I tried it again a couple days ago and found that it is not working.
    Where would I locate the fuse for the lighter?
  8. chetman7
    ^^ fuse box dummy :D
  9. OhMeOhMy
    If it's the fuse, why is the other cig lighter working.
  10. chetman7
    dunno.... mayb there separet fuses
  11. Guest
    because they r not on the same circuit. one is constant power and the other only works when the key is on.
